Efficient Electric boilers
12 Mar 2013
London
The cost of bringing gas to my property and installing a central heating system is prohibitive. I am considering alternatives.
I would like to be able to remove the internal cold water tank and the imersion heater and install instead an efficient electric boiler instead. is there one you would recommend?
lpg cheapest to get up and running. 2 47kg bottle and a boiler
and you are up and running.
That would barely cover the cost of an oil tank.
If electric boilers are 100% efficient at the point of use, does it mean that for a 2 bedroom flat, with only one shower, it is not necessary to have an storage heater as well?
storage heaters use off peak electric thats around 400% efficient [1/4 the price]
ok not more than 100% but around 75% cheaper at say 3-5p a unit off peak over 12-20p peak rate
With leccy heating a Heat Pump would be first choice and with flats a split air source heat pump maybe your only option.
If a HP is out of the question then a Storage Electric boiler is best, the other choice is a Flow Through electric boiler. The former will store heat that's generated on a cheap tariff, the later doesn't have that advantage
Establishing your cheapest tariff is a good starter regardless.
HTH
As always very informative big-all.
The disadvantage of electric storage heaters is a) Tariffs b) Difficulty in controlling the heat, when seasonal weather changes. I'd never recommend electric storage heaters, they're the work of the Devil.
