Phew!
I was talking about domestic kit, but I suppose the principal is similar.
I have never experienced this before.
I was changing a pendant yesterday. Powered up and did the Zs.
>1999 on the Alphatek. Yikes, thinks me, we've got a case of broken continuity on the cpc.
Luckily, a colleague was with me and he tried it using his plug in lead with a flying lead for the earth:
http://isswww.co.uk/Accessories/Alp...h-bond-Wander-lead-for-use-with-Metrel-range/
With this, he got 0.83 Ohms. We tried my method with his Alphatek & leads: >1999.
Then I rang our technical guru and he said that loops are not possible from dimmer-controlled fittings because the triacs limit the flow
of test current & this is why the reading comes back open circuit.
I did look at the dimmer and it was one of the huge old-fashioned ones (those that take up the whole back box, not just a small module), so I guess that made a difference.
This is the first time ever I've had a problem taking a Zs from a dimmer-fed light. Mind you, all the others have been modern dimmer modules. As long as the dimmer is turned right up, I've never had a problem.
It's true what they say: You never stop learning & I don't mind admitting I've learnt something from that episode!
Thanks Rob!
