Hi All,
I have a property with the old style fuse wire boards. I need an EICR certificate as well.
One tradesman has said they will carry out the EICR first to find any faults with the existing wiring and then change the board to a new consumer unit to finish the test and issue the EICR?
I have been told it would be additional costs if faults are found with the existing wiring/fuse board?
Is this the correct process or should the new consumer unit be fitted first and then EICR? Does it matter which way?
Thanks,
Abdul
Thanks,
Abdul
