- Joined
- 27 Jan 2008
- Messages
- 29,848
- Reaction score
- 3,709
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Seem to remember turned to liquid at around 70°C. Sodium maybe? There must have been a problem as it was dropped.
I've just had a quick look. Sodium and potassium have much lower thermal capacities than water, and lithium about the same as water - but all three of those (particularly lithium) in that 'column' or the periodic table would come with big problems (particularly the tendency for 'spontaneous combustion'!) ... and, as I suggested might be the case, I can't find any solid or liquid which would have a higher thermal capacity than water.Seem to remember turned to liquid at around 70°C. Sodium maybe? There must have been a problem as it was dropped.
The lower bath has my wife's e-bike in it, never used.
I've had a quick look at latent heats of melting/fusion. The first table I found (here) indicates that ammonia has a similar latent heat to water but all the other substances in the list are lower than water, other than aluminium and chromium (both about 18% higher than water) - although their melting points would obviously be far too high to be useful for routine heat storage.However, I've just realised that you are talking about phase conversions, whereas I was talking about storing heat without a phase change. Hence, as you said, it's the latent heat of materials (not their thermal capacity) which matters - so, when I have a moment, I'll look into that.
I would think far from a crazy idea, but is not one of the problems with any such approach is that it is not very (if at allBack at that time (70's) my plan was a house with a large cellar which I would fill with wax, and loads of pipes going through it. It meant the heat could be stored at a constant temperature (melting point) suitable for heating the house for a year. I found that you could choose a wax with a convenient melting temperature. It might have worked but I never got round to it.
I would think far from a crazy idea, but is not one of the problems with any such approach is that it is not very (if at all) 'controllable'?
That depends upon what BS3036 meant. It sounded as if he might well have been thinking of storing heat for a lot longer than 12h/24h ...No less controllable, than storage heaters presently are.
... the heat could be stored at a constant temperature (melting point) suitable for heating the house for a year.
Assuming the whole think was encased in good insulation, which is obviously part of the plan, then you only remove heat when you run water through the pipes, which then travels on up to your radiators or underfloor heating pipes. At the time I did the calculations and it really just depended on having a decent sized cellar.it is not very (if at all) 'controllable'?
Yes, that's roughly what I thought you were saying.Assuming the whole think was encased in good insulation, which is obviously part of the plan, then you only remove heat when you run water through the pipes, which then travels on up to your radiators or underfloor heating pipes.
I could perhaps have achieved that, since my my very large cellar is (at a rough guess/calculation) 150 - 200 m³At the time I did the calculations and it really just depended on having a decent sized cellar.
True - but, as above, if you were going to store the wax, for months, at a temp high enough for feeding the rads, it may have proved unrealistic to install adequate insulation?At the time, solar thermal tubes were also more prominent than PV, so it was just a case of taking the sun in the summer and using it in the winter.
I think what you are missing is the will to take on a challenge. The points you mention (most of which I already pointed out) represent the engineering challenges to be overcome. The storage temperature would have been chosen for optimal trade-off . Bear in mind that these days a lower temperature is considered best for the heat transfer than in those olden times. As for whether it would have been worth it to heat a house all year from the sun rather than paying someone for the energy - I thought that might be good value. However, as you may realise, I also did not find the resolve to take on this challenge, as I expected to move house more often than would have made this practical.am I missing something?
I don't think I missed much. It never really occurred to me that you might ever have seriously considered 'doing it', so I assumed that you were talking about an interesting academic/theoretical 'thought exercise'! When I asked whether I was 'missing anything', I was really asking about 'technical' issues, rather than practicalities or inclination to actually implement such a system!I think what you are missing is the will to take on a challenge. The points you mention (most of which I already pointed out) represent the engineering challenges to be overcome. ..... However, as you may realise, I also did not find the resolve to take on this challenge, as I expected to move house more often than would have made this practical.
Is that true? It's certainly the case that when heat is being supplied by a heat pump, lower temperatures have to be used (typically ΔT30, rather than the traditional ΔT50), necessitating more and/or larger radiators, but I wasn't actually aware of the lower temps resulting in 'better heat transfer'.The storage temperature would have been chosen for optimal trade-off . Bear in mind that these days a lower temperature is considered best for the heat transfer than in those olden times.
For the great majority of people in the UK, loss of electricity also means loss of heating by gas, LPG or oil, doesn't it (unless people have (which few do) 'standalone' gas, LPG or oil heaters that do not require any electricity to 'control' them) ?.... While we have reports of massive swades of the country being without power every time we have a named storm, sometimes for a week or more, electric heating is not going to work.
