The news item referred to was
Last Updated: Thursday, 22 May, 2003, 08:02 GMT 09:02 UK
Your arguement has assumed a 15 amp current occurred but has not taken account of the voltage needed to create a 15 amp current through the un-known resistance of the victim's body.
"simple" defibs calculate the current and time for the required charge to be dispensed into the casualty's body. The voltage is turned on and rapidly adjusted to give the required current. Then switched off when the required current has flowed for the required time.
Later more intelligent defibs measure the resistance between the pads before applying the shock and then calculate the initial voltage and time and waveform to apply.
http://www.resus.org.uk/pages/faqDefib.htm
http://tinyurl.com/qnhl76[/QUOTE]
I ignored resistance as that is delta R and is measured by inducing a small current and working out the voltage. Ohms law from there. Bi Phasic Defibs take the resistance into account. To work it out correctly I remember it been some calculus function. I was trained with the LP20 on that like I showed and a dummy called resus anny who had a large resistor in her chest, and when we did load tests we discharged the defib 15 times at 360J into a resistive load. We had a tester that would then log and record the results.
But even taking R into account its going to be infintatnley high so not going to introduce much change to the calcs I did.
I all ways remember we never really took resistance into account.
I think that they should have done an autopsy! This is all speculation and theroy but we do not know the actual cause of death.
Adam
