electric radiator switch fused spur question
9 Jan 2014
Devon
Hi
I have been asked to change a switched fused spur feeding a electric radiator for a NON switched fused spur ..this is because customers keep switching of the radiators, this messes up the timer.. is this ok to change?[code:1] thanks [/code:1]
You still need the switch, would it be better to re-locate the fused spur at high level, with a flex outlet unit at low level, to help avoid accidental switch-offs?
Or, make up a key switch and fuse module in a GRID system.
These are commonly made by MK and Crabtree.
This should fit on the existing back box.
