Hi all,
Had an electrician fit me a new shower cable. Since they've fitted it, when the shower is in use it heats up quite dramatically.
The cable is 6mm2 T+E, the shower is a 10.8kW (9.9kW at 230v) unit. The cable is currently in free air running as they are returning to run wiring to the garage and an outside light, but they mentioned running it in trunking up the wall. It has a 45A rated breaker.
From my little research on the subject, this seems the wrong cable, especially if they were to run it in trunking rather than bury in the wall.
Is this the correct size of cable?
