If you turn off the main switch (all circuits in the CU are now off) try and reset it. If it won't reset the MCB is faulty and you need a new one fitted. There may be a circuit fault as well.
If it will reset with power off at main switch, and trips as soon as you turn the main switch back on, then you have a circuit failure.
Unless you are familiar with electrical work, now is a good time to call an electrician.
