- Joined
- 21 Jul 2004
- Messages
- 43
- Reaction score
- 0
- Country
Hi all.
I have just replaced a 2 way light switch in my hall and am having problems getting it to work properly. I removed an old light switch and tried to replace the wires like for like but it was a different format.
Here is the switch after I have attached the cables.
The switch nearest the wall operates a hall light (hall) and there is another single switch at the other end of the hall which operates this light too. The switch closest to the viewer operates an outside light (outside).
I have attached the cables as follows;
Red - L1 (hall)
Grey - L2 (hall)
Blue - L1 (outside)
Yellow - L2 (outside)
I also have a grey cable going between the 2 com ports.
When I switched the power back on the lights worked and I was impressed however when I try and turn them on together they both go off! They only work 1 at a time. In addition the switch at the other end of the hall now does not operate the light either to turn it on or off.
I have tried changing the wires round but nothing yet has solved the problem.
Any advice on how the wires should be attached would be greatly appreciated.
If you need any other info please let me know.
Many Thanks in advance.
Russell.
Red - L1 (hall)
Grey - L2 (hall)
Blue - L1 (outside)
Russell.
