Electrical Assistance Required
You will need to be able to turn the fan off, so that it stays off when the lights are on, in order to clean it, surely?
Can only see that the lighting one being the only solution here, there is a model with a pull cord though but thats just asking never to be turned on and I assume that it needs to work? Only going to be me in there
If you had a pull-cord fan, connected to the lights, then you could leave its pull-switch turned on more-or-less always', so that it always came on with the lights, but could use the pull cord to switch off if/when you ever wanted to whilst the lights were on.
Kind Regards, John
From the very start the OP has expressed his intention to have an 'isolator' for the fan, even if/when fed from the lights.,
Kind Regards, John
Kind Regards, John
An isolator would not have to be mounted in a convenient location for regular use, instead the isolator simply needs to be mounted where it is handy for normal operation as well as isolation to work on the fan
Quite so. I think that has been pointed out a number of times (a few by myself!). As I've said, if he wants to keep the wiring all 'above ceiling', then the most obvious thing would be to have a ceiling-mounted DP pull switch (like a 'shower' one).
Kind Regards, John
IMO the isolator can be neater at the top of the wall, hard against the ceiling and in view from the fan. Very likely it will be about 2400mm above the floor; or at least 2250mm, which is convenient.
It's essentially a matter of personal choice.
Maybe "convenient", but "at least 2250mm" is, of course, totally irrelevant in an office (or, come to that, even a kitchen, which the room previously was) :)
Kind Regards, John
