Electrical outlets
CBW
26 Sep 2019
North
Morning all,
I have found certain answers via the forum, but couldn’t work something out.
I live in a 2009/2010 built property. I need to replace my washing machine, but don’t want to invalidate the warranty. The existing fused flex outlet is connected to a 4 gang switch plate. Can I just replace the plate outlet with unswitched, or would it need to incorporate a fuse? Thanks
from your description it implies that the w/m is hard wired ie no plug so a fused connection unit would be required or a normal socket and just plug the new mchine in as there will be a fuse in the plug
  • Thanks
Reactions: CBW
Sorry, I’ve just re-read what I’ve put. Existing w/m is hard wired, because the fused flex outlet plate is there, not a socket. So the new one states the plug can’t be modified, etc and I don’t want them to have an excuse for warranty breach, or so you think I can just hard wire new one in?
This is the existing one
Is the flex coming out of the bottom? (Is the picture rotated?)
Change the FCU for a socket and plug new washer into it.
  • Thanks
Reactions: CBW
But keep in mind, that a 13amp socket plus a plug will stick out from the wall further - it may force the machine to be further out.
you won't, even if you cut the plug off.
No, of course not. But it doesn't stop the hassle caused by the service engineer refusing to touch it when you have an in-warranty fault.
  • Thanks
Reactions: CBW
As said it is usually done like this, to create more room at the back of the WM, for it to go back further.
Ideally a socket should be fitted to one side of the WM
  • Thanks
Reactions: CBW
