hello there, on a periodic test if the lighting circuit was not rcd protected would that be a code 2 or 4 thanks
When was it put in/CU replaced...
if it was done to 16th (or previous) then code 4
if it was done to 17th then code 2
Theres one more now.there is to many smart a**s on here
Scousespark,
That's wrong too!
The PIR is done to the current regs so no RCD where there should be one (in the 17th) is a fault, done to 14th, 15th, 16th or 17th it doesn't matter!
EDIT oops sorry misread you! But I don't think the code changes, would normally be a code 4 even if it was done in the last year, IMO.
