AdamW said:brown-nought said:New builds should put sockets/light switches between 450mm and 1200mm off the floor.
When I find the idiot who passed that one... Hmmm, wonder if you could use an extra-large, extra-deep skirting board, count that as floor and then mount the light switches at (what most would regard) a correct, toddler proof, aesthetic height of 1500mm?
Anyone know the building regs as to what constitutes floor level?
ban-all-sheds said:Last post by millennium_boy 13th August.
First post by kai 15th August.
A 1960's house, still with it's original wiring is a can of worms, with many hidden dangers, such as decaying cables, green slime oozing from the cables, and undersized or missing earthing conductors, a full rewire is recommended - call in a professional electrician in to check it over.
yes the 450mm height I'm not keen on either, but as for floor height, the floor, as I see it, is the bit you stand on!!![]()
We need some extra plug sockets fitting in our 1966 semi - each room (except the kitchen and lounge) typically has just one single socket. I also want a new distribution board as I'm tired of changing fuse wire.
I had an electrician round last night who basically refused to do any work without testing the whole system. He spotted several old fashioned bakelite style sockets and suggested that he need to doing a full system check before he was allowed to change any parts of the system - including the distribution board. He expected that a complete rewire was needed. which would cost up to £3,000. Worse still we have cables running to the garage under several inches of concrete and all rooms are paped so it will be messy.
Our original plan had been to rewire as and when we decorated each room (we're currently doing 2 of the bedrooms and want the extra sockets).
Where do we go from here? He went on to say that it would soon be difficult to even get household insurance without having a electrical test certificate. Was he just trying to make a job for himself?
