electricity supply main fuse?
Pointless checking - If you have had no problems, leave alone.
It will no doubt be an 80amp on a modern property(1970 onwards....ish).
What DNO is yours??
If it says 100A to BS1361 IIb, then it probably is 100A to the best of my knowledge. The smaller rating fuses are physically smaller in my experience.
I am an electrical tester and i have seen 63A 80A and 100A in the holders. The 100A on the side is a maximum for the holder and not always an indication of the fuse rating
Not so - the service head will allways show BS1361, type II, 100A. They can have a 60, 80, 100 or occasionally lower.
Western Power fit 80amp as standard. This is due to the huge amount of 16mm tails still out in service.
The fuse rating doesn't reflect your maximum demand either - the maximum demand for most domestics installs is taken by the DNO as 15kW max. Above this, they will fit a larger cutout, with a 100amp or more fuse.
Testing what :lol: Shouldn't be in the DNO's carrier  8)
Ah - calm down - Im one of the worst snippers :roll: :lol:
Who dun that? Dunno?
I've hacksawed padlocks from DNO 800amp incomers in the past :twisted: Got warned for that though :shock: Bastards.
