How does having heating provided mean that they won't want kettles?
But apparently the concept that a "kettle is not a heater" is too hard for some people to understand. Or a toaster.Slow night eh B-A-S?
Just for clarity, if the landlord stipulates that there is to be no heating devices in the rooms for example a kettle, and there should be no requirement for heaters since he provides the heating then it is possible to limit the electrical use by using a smaller breaker. Actualy now I write that again, it is not a hard concept to understand first time around.
MCBs are not to be used as load limiting devices.
That is exactly the point of any protective device, to limit the load (or the current) in the circuit.
Your crystal ball was working.My crystal ball foresees a dissenting view!
to protect the installation from damage from cables over heating due to a high current caused by a fault.
Using an MCB as an automatic load shedding switch is NOT recommended as frequent operation of an MCB can alter the operating parameters such as the current at which the MCB trips. If you need to limit the load then use a device designed for frequent operation, such as a current sensor and a contactor
That makes sense, but are devices such as you describe readily available off-the-shelf - i.e. a 'current sensor' which provides a binary output ('on' or 'off') depending upon whether the current exceeds some (perhaps adjustable) threshold value?If you need to limit the load then use a device designed for frequent operation, such as a current sensor and a contactor
That's undoubtedly true, and probably means that, in practice, using an MCB for this purpose would probably be OK in the situation described, because only an idiot of a tenant would keep on plugging in something which they had discovered trips the MCB.Yes, using a device specifically designed to limit the load would be best but on the information in the original posts, this is a simpler, cheaper solution. it might be better since the tenant will very quickly learn that plugging in an appliance that draws a large current will trip their electricity, and they will stop trying to use them.
Mine doesn't, and I can't see how they could - unless it was, in fact, three separate single-phase meters within the same enclosure.Alternatively, I wonder if a three phase meter could be used, because these display the kWh for each phase separately as well as adding them up?
Both of the above are considerably cheaper here- https://www.universalmeterservices....ers-c-3.html?zenid=33tdbjkl3612pu7071h4vimc04This is another small DIN rail mount meter but of better quality than the Chinese one shown:
https://www.spwales.com/single-phase/ytl-dds353
Another type of meter is wall mounted, but you would need three of them:
https://www.spwales.com/single-phase/emlite-dragonfly
