- Joined
- 13 Apr 2016
- Messages
- 60
- Reaction score
- 1
- Country
hi
I have a "your loop" energy monitor on my electrical supply. Its been pretty good at helping me find things that are using energy in my house. It shows the at-rest load of my house (everything switched off / unplugged that can be) around 350W constantly, which is working out around £1 a day just for the background load, more than I would like.
However, when I last went on holiday I did something different - I switched power off using the MCB's to all circuits, other than the one that has the freezer on it. Using this method, and working out meter readings, the freezer is using a few 10's of watts only. So, the problem is I can't work out where the extra 300 or so is coming from.
I have already been round every room and unplugged / switched off everything .so I now think there must be something somewhere hidden by the previous owners that I don't know about , or had not considered as taking always on power, e.g an outside sensor light . I am currently mystified as to what it might be, so need to start a process of tracing to find it.
I can shut down circuits using the MCB one by one to see what happens to the load at the meter tails and I am quite happy to pop in the loft / under floors and trace cables to try find the miscreant as well.
To do this I will need something to tell me the real time power consumption level focused on the lower end of the spectrum (1.5 amps or less), clamped on to wiring.
Is there a clamp on meter with good enough low-end (<1.5A) power resolution in a DIYNOT'ers price bracket anyone can recommend?
