Enforcer and smoke detector
30 Apr 2017
Hello,
How do you configure your enforcer with smoke detectors, and particularly the bells?
My issue is that false alarms on smoke detectors happen. Should i have the full bells and whistles when it does?
You should have a control panel that outputs a DIFFERENT SOUND to your intruder alarm, on older alarm panels as far as I can remember used to pulse the fire signal.
Being so different to the normal noise you hear from alarm systems it makes people look (?) and hopefully .......
If this can happen with the Enforcer, I've no idea.
Never call it a Fire Alarm because it isn't.
As regarding the sound this should be both inside and out, who is going to hear anything inside in its own?
If you use a dedicated sounder in a box mark it as being a fire notification, use a different coloured strobe than the intruder alarm, red perhaps.
