    Dismiss Notice
EPDM Rubber Roofing
Discussion in 'Roofing and Guttering' started by Suffolkman, 17 Oct 2019.
  1. Suffolkman
    Suffolkman
    22 Oct 2012
    7
    Thanks Received:
    Country:
    I am building a detached domestic garage with a flat roof. I have been lookinhg into EPDM rubber roofing kits. Most companies seem to use two different thicknesses of rubber, a sort of standard and super. I can buy a kit with everything needed to do the job including the rubber sheet in one piece (so no joints to leak). Looking at the instructional videos the job looks fairly straight forward. Is it as easy as the videos make it look to do a DIY job ? Any pitfalls I should no about ? The roof will be 6 x 4 mt with a gutter down one of the long sides. With fibreglass roofing systems it seems to be recommended to lay the sheet on OSB3 T&G. Is it the same with EPDM systems or would 8x4 OSB3 sheets be good enough ? Any advice would be much appreciated. The company who are coming up with a competitively priced kit is Rubberflatroof.co.uk can anyone recommend them please...or another company maybe ?
    Many Thanks
    Suffolkman
  2. Sponsored Links
  3. bobasd
    bobasd
    2 Dec 2017
    2,373
    Thanks Received:
    448
    Country:
    see "fixmyroof" vid's on youtube - he shows both systems - and lists materials suppliers fwiw.
  4. ^woody^
    ^woody^
    3 Sep 2006
    28,669
    Thanks Received:
    3,642
    West Mids
    Country:
    Yes it's easy.
    Check out Permaroof who supply everything, including how-to guides.
  5. Suffolkman
    Suffolkman
    22 Oct 2012
    7
    Thanks Received:
    Country:
    Thanks both for your replies. I must admit that looking at a couple of videos already...it does look pretty straightforward. I will check out YT tomorrow. Was hoping someone will advise me if I should use T&G OSB or just regular 8x4 OSB.
    Suffolkman
  6. martin hill
    martin hill
    7 Oct 2019
    423
    Thanks Received:
    76
    salford
    Country:
    Just come on here for some advice myself. But you do use OSB3 Boards. I going to use just the 8 x 4 as joist spacing only 400mm. I looking at a Firestone kit for EPDM. Seems good. Any people on here got any thoughts for me and Suffolkman. Suffolkman if you near to the coast i'd go for a pitched roof if you can get permission for it. Not sure if flat roof will wear as long in coastal weather.
  7. Sponsored Links
  8. catlad
    catlad
    29 Jul 2011
    4,004
    Thanks Received:
    543
    Lancashire
    Country:
    Osb3 T&G is the way to go, before you fix the first sheet down permanently put a few boards together first as it will stop you being out of line from the off.
  9. foxhole
    foxhole
    14 Mar 2006
    15,729
    Thanks Received:
    1,729
    Kent
    Country:
    I only struggled with gutter trim as any seams are twice the thickness the trim is designed to accept .
  10. Suffolkman
    Suffolkman
    22 Oct 2012
    7
    Thanks Received:
    Country:
    Thanks for further advice. no I am not near the coast. Will look into the gutter trim problem. Most suppliers seem to do two thicknesses. The thicker only working out at another £50 or so. Will probably go for that.
    Suffolkman
  11. Jono11
    Jono11
    6 Jan 2012
    63
    Thanks Received:
    Essex
    Country:
    I did it myself and am not a roofer or tradesman. It was easy. I went for the standard thickness as the seller said the thicker one was more for if you were going to be walking on it often.
    I can't see it ever failing, it's been up for 5 years now and still looks as good as day 1.
    Be careful to lay it flat on the glue without wrinkles.
    The edging was the hardest bit and once you have nailed the plastic trim in place there is no removing the nail without damaging the trim.
  12. Notch7
    Notch7
    15 Sep 2017
    17,841
    Thanks Received:
    1,251
    Sussex
    Country:
    Ive used bbth thicknesses -and both seem fine.
    For a big garage roof I would go for the thicker option. Just bare in mind the weight -you will need to be very strong to lift it on the roof!
    I unrolled my 6m x 5m rubber, then rolled it up as a carpet roll 6m wide. Then got one end up on the roof by pulling it up 2 long lengths of 8 x 2 leaning against roof.
    My tips:
    I laid the rubber in place on the roof for a few days to flatten as it comes with serious creases -ideally a few hours of sun to get it hot really helps to ease out the folds.
    The rubber comes coated with silvery dust, some sort of release agent to stop it sticking together in manufacture -I used a henry and scrubbed it as best as poss to remove the worst.
    The water based glue does not work well only applied to one surface -I coated both rubber and epdm.
    The contact adhesive has 100% grab within seconds and will not release. To avoid risk of rubber blowing over before positioning put weights on folded back rubber whrn drying, then once touch dry lay some battens down on the glued roof section and move them back as the rubber is worked into position. (Only use contact adhesive where needed.
    I bought a heavy duty roller made for karndean -I found it brilliant for rolling the glued areas.
    The penny roller is worth it if you have internal corners and or upstands to do
    https://www.amazon.co.uk/Amtico-kar...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
    I bought from rubber4roofs -they have good videos and written guides.
    Every order Ive made they have delivered next day. They arent the cheapest.
    AFAIK there are only 2 brands firestone and carlisle both American.
    • Thanks Thanks x 1
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
