I think the most you can expect (if anything) is 'stills', not any videosI for one will definitely subscribe, if you were to start posting teardown videos on YouTube!... I'm sure flameport wouldn't mind the competition
Kind Regards, John
The inside of my 1652 (see below) looks identical to my previous one - but, as you can see, very different from the 1652C in the video.An unpopulated 'BT2'.... Though as you say, this is the 1652'C' - good luck!
Slight delay - I have been distracted by having to address an 'acute plumbing problem'.... There's absolutely nothing visibly wrong so far, so the next step is to remove the 'top' board (well, actually, the bottom one - I wasted some time because I had forgotten that it's the bottom, rather than the top, part of the casing which comes off first!). More 'watching this space', I guess!
Thanks. I'll have a look. [plumbing now sort-of sorted, so I should be back on MFTs fairly soon!]A good source of information in regards to repairing test instruments, is [email protected] - I know it says Marconi, which is the specialisation, they do cover other other manufacture's instruments too. There is also a more general website forum, but they tend to deal with the really old test equipment repair.
Eureka!! - I think/hope... There's absolutely nothing visibly wrong so far, so the next step is to remove the 'top' board (well, actually, the bottom one - I wasted some time because I had forgotten that it's the bottom, rather than the top, part of the casing which comes off first!). More 'watching this space', I guess!
I suggest that you continue 'watching this space', although I obviously hope not to see any changes that I need to report!
Thanks.Just a thought - have you considered that your simply swapping the boards over, might have cleaned the oxide from the contacts and ribbon cables? Try swapping back to the original board maybe?
I'm on tenterhooks!However, I have very recently (just a few minutes ago) 'noticed something', which may mean that there will be a 'new chapter' to this saga, so some continued 'watching of this space' is probably still necessary![]()
Maybe, but I'm a little nervous (I could do without 'further chapters of the saga'I'm on tenterhooks!![]()
I was right to be nervous - this is seriously annoying since I seem to have managed (arguably 'unnecessarily') to put myself back to square one!Maybe, but I'm a little nervous (I could do without 'further chapters of the saga'). Clarification soon, I hope!
I don't think that I have got any such product to hand, but I'll have a think/look around.Did you try using a product like De-oxit on the ribbon cable connectors & sockets, seems to me like the only thing you have been disturbing & they are notorious for becoming contaminated as Harry suggested.
My 'looking around' reminded me that I do have some WD40 "Specialist Contact Cleaner" - would that be 'safe' for this purpose (it's label implies that it ought to be)?I don't think that I have got any such product to hand, but I'll have a think/look around.
