Hi.
I've just gone to replace what I thought was a standard ferloc 528 and eurolock cylinder on a door (should have been a 20 min task) and found that the euro cylinder will not come out of the door. It appears to totter around the retaining machine screw point though, even though that has been removed.
I can't see around the cylinder, even with the handles fully removed, because the PVC is very close to the cylinder.
I can only imagine that the cylinder is screwed in from the other side, ie to remove it, the DG unit has to be removed, which I'm not comfortable doing.
Is this likely situation? ? Ive replaced other cylinders in other doors without any problem.
Ta.
Ta.
