Expansion gaps for engineered
12 Jul 2005
Bedfordshire
Hi all,
I would like to install a 15mm thick ply/oak engineered wood product into my living room which is about 3.5 m x 3.5 m. The product is click lock.
On one wall there is a 3m wide internal bifold door set which has an oak bottom track, and it would look considerably nicer to lay the flooring right up to this track for a seamless threshold.
In a room of this size, would it work to omit a gap between the flooring and this bottom track, leaving a larger gap on the other 3 sides (as well as the ~25cm either size of the track) to accommodate?
thanks
slip
Should be ok assuming the floor runs away from door as most expansion occurs across the boards rather than along it .
