Extending boarded area
Discussion in 'Floors, Stairs and Lofts' started by whenisayjump, 7 May 2020.
  1. whenisayjump
    whenisayjump
    2 Sep 2015
    63
    Thanks Received:
    Country:
    Hello,
    I was wondering if anyone could give me some advice.
    I live in a terraced house, and the joists run front to back. In the loft the previous owner (or maybe the developer dunno) has boarded the centre of the loft, but for some reason they've not boarded up to the wall, they left the first two joists with no boarding (so the joists on the right and left if you were to look at the house from the outside).
    Unfortunately they've boarded right to the edge of the last joist, they've not left enough room to put down another board. So, rather than take up the boards that are there and cut them back slightly, would there be any issue to lay the new board so that it overlaps the old board slightly and add some batten beneath the new board to make up the height different where it touched the currently exposed joists.
    Whilst I know it's not the best way of solving the problem it certainly seems the simplest (and yes I know I'm a terrible bodger :().
    Thanks in advance.
  2. foxhole
    foxhole
    14 Mar 2006
    18,204
    Thanks Received:
    2,088
    Kent
    Country:
    Add baton to below edge of joist to accept further boards.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. whenisayjump
    whenisayjump
    2 Sep 2015
    63
    Thanks Received:
    Country:
    I did consider that, but I was a bit concerned if I messed it up then the plank relying on joist extension could give way and be a bit dangerous?
  5. foxhole
    foxhole
    14 Mar 2006
    18,204
    Thanks Received:
    2,088
    Kent
    Country:
    Screwed to joist it’s as strong as sitting it on joist.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
