I need to move an outbuilding cu atleast a metre further from the door as I need to increase the size of the entrance door.
To move the cu that little bit, the swa will not reach the new location so I was planning to run the swa as far as I can along the wall and then join it in an enclosure box using henley blocks.
Then run meter tails from the blocks to the cu.
Its two core swa with the armour used as the earth. Can I connect the armour into a Henley block, and then a length of earth cable to the cu?
Is this ok as I can't think of an alternative.
Cheers.
Cheers.
