Hi
I am looking to extend my 1930 semi detached house and I'm just deciding to either extend single storey or double. The reason is that the roof of the existing house is causing the dilemma. Basically the existing house has a hipped roof and the last part of the roof cuts into the top bedroom where it meets the eaves (see picture attached as i do not know the name of this type of roof where it essentially cuts into the room). This lowers the ceiling height from 2.4m to 2.05m. So if we added in a doorframe to lead into the new extension on the first floor it would look strange (as the top of the doorframe would be almost at ceiling height).
So far I have only managed to draw one idea which is basically what my neighbour has done which involves tying in the pitched extension roof into the existing roof. but they just had their 2 meter extension to extend the existing room and said 15 years ago it was very expensive to roof it. Plus they only extended 2 meters on the first floor and 3 meters on the ground floor. I would like to extend further if possible.
The only other vague idea was to not tie in the extension roof and maybe have a hipped/pitched roof on the extension a valley guttering between the new and old roof? but I feel this maybe would not work as the eaves height maybe would be a problem?
Anyway any advice or ideas would be great! in regards to making a double storey extension roof look appealing and require less work than the attached idea. Ideally the only roof type i would like to avoid is a flat roof.
Existing plan
proposed idea 1
Nick
Existing plan
proposed idea 1
Nick
