I let a property in England and the tennant has moved out recently. I am currently in dispute with him over a number of areas with one being an exterior light that he installed.
He attached a light to the exterior wall of the house, ran the cable up to the back bedroom window, drilled a hole through a upvc window frame and plugged the cable into a socket.
Aside from the fact that he damaged my window and did not have permission to do any work, he is claiming that an electrician did the work and that there is nothing dangerous about it.
I was sure that if you fitted an external light there you could not run it from an internal plug. I even thought that it should be on a seperate circuit. His argument is that water cannot run up an insulated cable...
Can any one give me some guidance on this or point me in the direction of what regulations / legislation this would be covered by (if any). I have tried a bit of a google search but just seem to find sites selling outside lights!
