Yes you can fit an external socket.
You say to an existing ring. How do you know that it is a ring final circuit? (If it is then yes)
If the circuit is RCD protected then you do not need a socket with another RCD.
I'll clarify Andy's post.
I'm replacing the whole kitchen ring. I wanted to check if it was ok to include an external socket on this ring. I get now that I can do that, as long as the ring has RCD protection, which I'll put in.
