Hi all
I'm about to install an in-line extractor fan in our main bathroom. It has a window, but we still get condensation problems as we often have to leave the house very soon after showering for work, so the window doesn't stay open for long enough. It also makes the bathroom freezing and it's only heated by a puny towel heater as it is!
Anyway I have some questions that it would be great to get answers to if possible.
1. There used to be an electric shower in the bathroom, which has now been replaced by a thermostatic mixer off the combi. Since there is now a spare power cable, can I use this to feed the extractor fan rather than spurring off the light circuit? The shower was run from this switch (on the left) and my intention is to use it to switch the fan on and off:
Would I just need to reduce the fuse in the consumer unit to an appropriate rating? What should an extractor fan be fused at?
2. My plan is to use an in-line fan and run the ducting across the attic and vent through a hole in the soffits, probably by removing this old overflow pipe:
Is this sound?
3. Do you have any specific recommendations for in-line fans that will extract a decent volume of air? I don't want one that barely satisfies regulations, I want it to do a good job of reducing moisture in our bathroom.
Many thanks for any tips / opinions / advice.
Is this sound?
