extractor fan very close to the shower
29 Dec 2017
Scotland
is it normal for a extractor fan to be this close to the shower. It looks too close and in a position where it could be accidentally sprayed with water if someone were to actually use the shower. Is this acceptable or a obvious building code violation
View media item 103145
20 Jul 2005
Nottinghamshire
It depends upon the fan. There are many that are suitably designed for installing in Zone 1 of a bathroom (ie inside a shower cubicle) they are usually rated at IP45 or above. The installation instructions for the fan will tell you. If you don't have them, you can probably find a copy on line. 230V fans should also be protected by an RCD.
28 Jul 2006
Oxfordshire
Its a Vent Axia. Need the model number, probably on a label on the underside.
My, that's a long pull cord!
29 Dec 2017
Scotland
The label is rather faded however it does claim to be “safety extra low voltage” as for the pull cord It about 3 feet long.
I don’t use that shower anyway as I don’t trust electric showers. I was just wondered if the close proximity of the fan was compliant with building code.
28 Jul 2006
Oxfordshire
In that case it is a 12v fan (there should be a transformer box, somewhere).
It is designed to be in locations where mains fans are not permitted. Like in a shower!
It’s fine.
28 Jul 2006
Oxfordshire
Yes...
but doesn't that pull switch fall under the following heading for zone 1?
Only switchgear with a maximum 12V AC RMS or 30V DC SELV may be installed
7 Jul 2010
Retired to:
Portugal
"701.512.3 Erection of switchgear, controlgear and accessories according to external
influences
The following requirements do not apply to switches and controls which are incorporated in fixed current-using
equipment suitable for use in that zone or to insulating pull cords of cord operated switches."
