My bathroom extraction fan and light operate from a single wall mounted switch which is annoying as it means you cant have the fan on without the light. The fan is installed with a fan isolater switch (mounted hight above the bathroom door) so I can isolate the fan and only operate the light which is fine but I want to be able to operate the fan and light independantly using a 2 gang switch.
The current wiring configuration is;
Single switch with all blue wires fixed together is a piece of terminal block. brown wires (from fan and light) fixed into switch in L1 and L2.
Would it work if I were to separate the brown wires so that I use a 2 gang switch and put the brown from the fan in one side of the switch (L1 and L2) and the brown from the light in the other side of the switch (L1 and L2). This sounds feasible but would it work?
Any advice would be very helpful.
Nick
Nick
