Are you saying that the current temporarily passing through the failing lamp exceeded the rated capacity of the switch?securespark said:The failure of the lamp caused the dimmer to toast...
If so, would the result not have been the same if the switch had been off at the time the lamp was inserted, and the circuit energised afterwards?
OOI, do BS1361 fuses have stated 'type', compared to MCBs?RF Lighting said:The short took out two 32A type B breakers (no discrimination) while leaving a 13A BS1361 intact.
