I've just moved into a new house and now all those annoying problems are coming to light (no pun intended)
The previous owner did alot of work but also went downlighter crazy in the kitchen. There must be about 16 (14 off one swith and 2 off another switch in an alcove). Sounds like a football stadium but the affect is quite good. I have two bulbs that don't work (one off both switch), so I did the obvious thing took out the old ones, put in the new ones and hey presto nothing.
So I tried another new bulb again nothing, at this point I started changing bulbs with existing bulbs I knew worked in case it was the bulb and not the socket that was faulty. Long and the short of it bulbs are ok but the socket (which is one of these sealed units appears to be at fault).
How can I check if it is the socket that these little halogen bulbs slot into are at fault as they are so small won't accept elec screwdriver (checking if there is a current)? How easy is it to replace the socket. Bearing in mind that I didn't install so working out how someone else has done something is always entertaining. Minor point the kitchen is in an extension with a pitched roof and no obvious access to roof void. It may be possible to gain access for one of the lights from the floorboards upstairs
(yes, only just thought of that...)
Now for the bathroom....there are only four downlighters in there, but I regular have two of them go out after the other lights have been on for 5 mins etc, sometimes they come back on again just like that, and sometimes I have to turn the lights off and on again. Is it because there are downlighters in the bathroom? I wouldn't think so as the faulty lights are furthest away from steam etc, are they overheating and turn themselves off
Any help would be appreciated.
