FAULTY WASHER???
23 Apr 2005
Lancashire
I have started to get minor shocks from my washing machine. I have tested the earth wire with an electric screw driver and there seems to be a current running through it.. i may be stupid but this can't be right, can it????? HELP!!!!
I'm no expert but if you're getting a current through your earth wire then from what I know it isn't actually connected to earth which must be the problem first thing I'd do is check earth continuity and the voltage and current reading on the earth there must be a break somewhere
Remember electric screwdrivers pick up even the most minute currents
First of all. Stop using the appliance
Secondly, call in an appliance repair engineer to check out the machine
Thirdly follow the picture below re the screwdriver or ONLY use it to undo screws!!
At the same time, it is well worth checking the EFLI to that socket and whether you have PEB's to your incoming pipework.
best checking earthing in house and your protection you should never beable to get shock if everything is working right
Washing machines often have a mains filter built into them in an attempt to remove electrical noise.
In the event of an open circuit on the earth wire anywhere on the circuit this can pull the voltage up to around half the mains voltage (capacitive coupling).
First place to start would be to check the earth wire in the socket is nice and tight.
Do you have a multimeter?
