Hi...
Not sure which is the best place to post this so have gone for general DIY....
Just had an old gas fire with balanced flue removed and now looking to fit a new electric fire which granite hearth, granite back panel and solid pine surround. the whole 'suite' will be fitted to a flat plasterboard wall. All of the components of the new suite were sold as a package from the store we bought them from, therefore you wouLd 'assume' that they are all compatitble with one another and will 'fit' properly. However, the one thing that i can't see working is fitting the spacer that came with the electric fire to the wall (as instructed in the fire installation instructions for flat walls) and then fitting the granite back panel around it. This is because the spacer is wider and taller than the cut out in the granite back panel (i hope that made sense??)
therefore i can only see one option and that's having to fit the pine surround, the granite back panel and the hearth and then securing the spacer to the front of the back panel the securing the fire to the spacer (as instructed) !! is this advisable though? - screwing into the granite?? i have my doubts! i don't think i will have the clearance when the back panel is fitted, between the back of the back panel and the wall to fit the fire without the spacer. HELP!
any comments, help, advice appreciated
Ben
Ben
