D
Deleted member 174758
Yes
You can get a relatively cheap (£11.99) drawer handle drilling jig made by Hafele from Screwfix. Toolstation also do the same jig, but are a quid more expensive. Solves a lot of the consistency problems folk have in hole positioning vfor lesscthan the ckst of a door. You can use a combi square, but I find it needs more than one because if you have to reset one frequently, inaccuracy creeps in and you might just drill a door in the wrong place at some point (don't ask.how I know!). Drill from front to back and clamp a piece of scrap MFC, plywood, MDF, etc to the back face of the door (2 clamps) to prevent blow out where the bit exits the door. Use a brad point centre bit - 6mm. That will get covered by the screw head but l gives you a bit of 'wiggle room' to cover not drilling dead straight (i.e perpenficular to the back of the door - not all doors have s flat face), etc. Buy some of the snap to length type screws (pennies) to replavce OEM ones as they are easier to cut to length (which will in sny case require a junior hacksaw, a file and handle, and a pair of pliers or a small portable vice to do)
You could make mitre cuts (very tricky) or you could straight cut and edge band the end panels and install them so they overlay the ends of the (trimmed) back panel
What about angle brackets (with short screws into the panel) and secure to the floor.
You'd screw the top of the panel to the underside of the worktop, use two three brackets at top and bottomHow would you deal with the top as I guess bracket on the floor only would make it wobble and fall down. What about the internal width I`m supposed to leave between the last unit and decor panel?
