Could someone please tell me what is the corrct way to fit a cooker hob.
Some say it is ok to use a cooker hose as long as the hose is not subjected to heat more than 70c and others say copper pipeing must be used with an isolation tap fitted.
If copper pipeing is the correct method, what are the fittings reguired to fit onto the half inch pipe fitted to the back of the hob.
Into this fitting runs the 15mm pipework gas supply = should this be soldered or can a compresion fitting be used.
The 15mm gas tap feeding the cooker does this have to be soldered or can you use the compresion type.
Thanks guys for your help
