S
Shutpa
Buying a new gas hob from Currys but their guys cant fit it for 2 weeks. Phoned 3 local plumbers but they are all too busy (or my job is too small). Are there national plumbers who do minor jobs?
Thanks for the replies guys - found an on the way home job man. My next problem is to find a hob that fits the 545x480x40mm recess left by the last one. Since the cut-out sizes aren't displayed, how do find out what the correct dimentions should be?
PS If anyone knows of a stainless stell hob with the usual 4 burners at around £150 to £200 that would fit the gap I'd be grateful to know about it.
Cheers mate. Comet are excellent at providing the required cut-out sizes but all are either too big or too small. Will now go to the joinery forum to find an easy way of enlaring the existing gap.might not be too easy, but you could try random MI's via google for hobs as the cut out size will be documented
I've just fitted a new Bosch hob (it was more than £200 though) but the cutout was 560mm x 480mm so would simply need the recess extending a bit. So long as your new hob needs a bigger cutout and not a smaller one you should be okThanks for the replies guys - found an on the way home job man. My next problem is to find a hob that fits the 545x480x40mm recess left by the last one. Since the cut-out sizes aren't displayed, how do find out what the correct dimentions should be?
