Fitting a TV bracket to a stone wall
17 Jun 2018
I have a tv I want to fit on a stone wall in a cottage.
I want to put this up without any hassle but unsure how to do it . The advice I have been given is to fit a piece of wood on the wall and then fit the bracket to that .Really dont know if that is good advice.
Has anyone ever fitted a tv bracket to a stone wall? this is a 32 inch television if that helps .
If the wall is flat then just drill plug and fix, if it’s an uneven surface a small sheet timber fitted first will help .
I can almost guarantee that when you drill for this, some of the holes will miss the stone and be into the "whatever crud was used to stick them together".
So the piece of wood first is actually good advice, because you are not having to use defined holes in the bracket - you can actually drill small test holes first to see where the stones are then with some clever marking, transfer those onto the wood and screw that on first, then fit your bracket onto the wood.
My house was built in 1855 out of stone and what appears to be horse poop and coal dust for morter. (it may not be but thats how good it is for sticking screws into) :)
