    Dismiss Notice
Fitting mains powered smoke alarms.
Discussion in 'Electrics UK' started by Grant_, 18 Oct 2021.
  1. Grant_
    Grant_
    19 Jan 2021
    22
    Thanks Received:
    Country:
    Hi All
    With the upcoming change to the law in scotland that says all smoke alarms need to be interlinked looming on the horizon I've been looking around at interlinked systems and Im wondering. as it is I have mains powered smoke alarms in most of the locations covered by the regs
    When I look at mains powered replacements they state that the need to be fitted by an electrician. What I can't seem to find out, is this the assumption that an electrician is required to provide amins connections or would even swapping the existing smoke alarms need to be done by an electrician and signed off?
    Also the house currently has a smoke alarm in the kitchen and one in the downstairs bedroom which is accessed from the kitchen. anything that produces the slightest whiff of smoke will set these off. I know the kitchen can be replaced with a heat alarm, but can the same be done for the bedroom?
    Grant
  2. Sponsored Links
  3. winston1
    winston1
    11 Jan 2010
    7,189
    Thanks Received:
    555
    London
    Country:
    You don’t need to do anything as the new law won’t be retrospective.
  4. Grant_
    Grant_
    19 Jan 2021
    22
    Thanks Received:
    Country:
    Sadly not the case
    From the scottish government website
    "From February all homeowners will be required to have interlinked alarms under legislation brought forward after the Grenfell Tower tragedy in 2017. These alarms significantly reduce casualties by alerting everybody in a property to a fire. Most homes will also require a carbon monoxide alarm."
    While not illegal, not updating the existing alarms would potentially invalidate home insurance etc.
  5. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,456
    Thanks Received:
    4,199
    Retired to:
    Country:
    Portugal
    That does seem unlikely even for the People's Socialist Democratic Republic of Scotland.
    How long do they give everyone to update their systems?
  6. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,546
    Thanks Received:
    2,132
    Oxfordshire
    Country:
    :LOL:
    Are you sure? The Scot gov web site says that
    By February 2022 every home must have:
    • one smoke alarm in the living room or the room you use most
    • one smoke alarm in every hallway or landing
    • one heat alarm in the kitchen
    All smoke and heat alarms should be mounted on the ceiling and be interlinked.
    It says nothing about retrospective. It says that in six months time if must be done. laughingly it goes on to say
    If you install a mains-powered system rather than sealed battery alarms, this may require a building warrant to be obtained from your local authority verifier before any work starts.
    So, 4 Million building warrants to be processed and work completed in less than 6 months?? :LOL::LOL::LOL::LOL:
    Anyway, Whinne. Please explain what makes you think the law will not be retrospective ?
  7. Grant_
    Grant_
    19 Jan 2021
    22
    Thanks Received:
    Country:
    Private rented and new-build homes must already meet these standards, but from February they will apply to every home in Scotland, regardless of age or tenure.
    https://www.gov.scot/news/changes-to-fire-safety-laws/
    Last I checked I wasn't living in a tower block with cheap illegal cladding, so I assume someone involved in the decision has a stake in a smoke alarm factory
  8. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,456
    Thanks Received:
    4,199
    Retired to:
    Country:
    Portugal
    February is only three months away. Good luck.
    • Like Like x 1
  9. Grant_
    Grant_
    19 Jan 2021
    22
    Thanks Received:
    Country:
    I assume most folk will chuck up sealed battery usints to replace their existing £10 from tesco and never tested smoke alarms
    Be hilarious if the councils did get swamped with building warrant requests though.
  10. Sponsored Links
  11. Grant_
    Grant_
    19 Jan 2021
    22
    Thanks Received:
    Country:
    Funnily enough none of the companies who are posting flyers though the door or running full page adds in the papers can be bothered to answer their emails.
    Battery powered units seem to be about £80 a pop at the minute, but I'd like to find out if i need an electrician to replace existing mains powered alarms for insurance or some other reasons or since the wiring is already there is it much different to replacing a ceiling rose which I'm happy to do myself
  12. flameport
    flameport
    10 Mar 2007
    9,920
    Thanks Received:
    1,988
    Poole, Dorset
    Country:
    They need to be installed correctly by a competent person. Not necessarily an electrician, although instructions will usually state that as for new installs additional wiring would be required and in some cases a new circuit.
    If you already have mains powered alarms, the replacements can use the existing wiring. If they are not already linked via the wiring, the interlink can be wireless.
    Heat alarm in kitchens. Optical smoke alarms in other rooms.
    Older devices were usually ionisation detectors, which were ultra sensitive to invisible particles created by cooking. Optical ones are not.
  13. winston1
    winston1
    11 Jan 2010
    7,189
    Thanks Received:
    555
    London
    Country:
    I doubt that as well but they may “try it on”.
  14. winston1
    winston1
    11 Jan 2010
    7,189
    Thanks Received:
    555
    London
    Country:
    Electrical regs are not normally retrospective. Every tiny Croft or bedsit is never going to get this done in three months are they?
  15. flameport
    flameport
    10 Mar 2007
    9,920
    Thanks Received:
    1,988
    Poole, Dorset
    Country:
  16. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,546
    Thanks Received:
    2,132
    Oxfordshire
    Country:
    Ok, @winston1. Will you retract your incorrect post? An innocent reader might be thrown in a Scottish jail if they followed yet another piece of your bad advice.
    • Like Like x 1
  17. winston1
    winston1
    11 Jan 2010
    7,189
    Thanks Received:
    555
    London
    Country:
    Whatever. It is still completely unrealistic to update every home in that time. No one will be thrown in jail.
Loading...
Share This Page
