I wish to fit a shower pump on a standard gravity fed vented system.
There isn't much room in the airing cupboard for the pump. Currently he shower is fed by a cold feed which comes off the cold water tank, down into the airing cupboard, then tee's off back up up to the loft, over the loft then down into a built in wardrobe where it enters the back of the shower cubicle. The other end of the cold feed from the tank continues around the house.
The hot feed comes off the top of the cylinder, then tees off the vent pipe (with a flange I expect), this then has another tee, one half which goes to the taps around the house and the other which goes again back up to the loft and follows the same path as the cold to the wardrobe and shower.
The pipes the shower runs off are a dedicated supply, albeit off the main distribution pipes from the cold feed and cylinder. Can I site the shower pump in the wardrobe which is about three metres away from the cylinder (horizontally) or about 20 metres away in pipe length? All 15 mm.
What's the reason for siting the pump so close to the cylinder?
Thanks.
Thanks.
