Fitting skirting board where there is no plaster
7 Apr 2008
Nottingham
Hope the title makes sense.
On ground floor with concrete base there is a gap about 4inch where no plaster is (due to damp rising I think)
Anyway, what is the best way to fix skirting board over this?
I would like the idea of expanding foam - squirt to back of board, gripfill to top of board that will sit on plaster, stick it on and hold it?
Or will this not work? lol
any tips?
cheers
Traated tile battern packed and screwed to the wall plumb with the face of the plaster will give you something solid to fix your skirting to.
Probably not - much more likely to overexpand and bow-out the skirting. As LadyLola says you need some form or other of packer. At a pinch and in the absence of other materials I've even used gobs of GripFill in the past - not ideal and there are limits as to how much of the stuff you can use (reallu only useful where the skim is thin) but meant that I could move on to the next issue
Cheers for the replies.
Yes I did think the foam may bow it out eventually. (I've never had much luck with the stuff)
Packing strips it is then,
cheers again
Render the gap ,with sharp sand and cement prime the gap with diluted unibond, overfill with render then screed of with straight edge,prime skirting backs then fit skirting as normal
And if you are really worried about the damp you could always add a waterproofing additive to the cement.
