Hello,
I've tried searching and i've got the same problem as mentioned in this thread:
- http://www.diynot.com/forums/viewtopic.php?p=346320#346320
However, The answer posted hasn't 100% cleared things up.
The strip i'm planning to use is curved, so if I were to mitre the two horizontal trims then I would be left with a point sticking out over the curve of the vertical trim...
Any help / products I could use would be brilliant.
Thnx, Jason.
I'm tiling half way up a window reveal so I have two external corners to put trim around.
Trouble is I can't work out how to do the joins where the three trims meet (horizontal along wall / horizontal out of the window reveal / vertical up the window reveal).
Can anyone help please?!
jimbocam
What you have to do is cut the upright (vertical) strip straight, fit this first between the tiles, then mitre the two horizontal strips to form a 90 deg mitre joint and fit this behind your top row of tiles.
The centre of this mitre joint then sits over the top of the straight cut of the vertical strip.
Hope this helps
Thnx, Jason.
