    Dismiss Notice
Fixing a leaking sunroof (BMW x3, 2007)
Discussion in 'Car Repairs / Maintenance' started by Bluebirdnick, 16 Aug 2020.
  1. Bluebirdnick
    Bluebirdnick
    13 Aug 2012
    48
    Thanks Received:
    Essex
    Country:
    Hi all
    I've got an old x3 which has a large panoramic sunroof. I rarely use the sunroof.
    It leaks. a lot. This is, apparently, very common for this model. As I understand it, the problem isn't so much that water gets through the seals and into the car; but that the pipes that drain the water away from the sunroof casette have perished and so water just floods into the car. It seems that there are 4 of these pipes (one in each corner), and so far only one has perished/broken. So in the boot on the drivers side, it fills up with water when it rains. And it is a lot of water - well over a litre in an hour or so in the rain yesterday. When we first had this issue, the problem was that the pipes were blocked. The garage cleared the pipes and it was fine for a year or so, but we've got the problem again and the garage tell me that the pipe/tube/whatever in that corner has almost certainly failed completely now. Apparently the water gets in through the entire sunroof i.e the seals around the fixed panel as well as the part that retracts. And it is not something we can really live with. The battery is in the boot and when I last checked it was sitting in a pool of water. And it also results in the electrics going bonkers - the boot, for example, sometimes refuses to open, and the rear windows open and close randomly.
    The BMW garage tells me that the cost of repair - which would involve stripping the car down to get to the pipes and replacing the entire sunroof casette - is well in excess of the value of the car- the parts alone are likely worth more than the car is. So that is not really an option.
    Any ideas? Here are my own thoughts on potential fixes. Note that I don't much care what it looks like, I just want to stop the leak so I can use the car for another year or so:
    1) Silicone. Lots of it, applied liberally from the inside, around the underside of the seals to cover the gap between the rubber and the metal body. I'd also open the sunroof, put silicone all over the inside of opening; and then close the sunroof again so that is squishes into the silicone. And then apply roof sealant from the top, around the seals.
    2) As above, but instead of the roof sealant, applying vinyl wrap over the entire roof, including the sunroof. (This was actually BMW's suggestion - but I've tried any number of vinyl wrapping places and none of them is willing to wrap over a sunroof)
    3) buy a wide roof box.
    4) replace entire roof with one without a sunroof.
    5) give up and buy a new car
    Any thoughts/suggestions? I can try DIYing the vinyl (I don't really care if it looks a bit rubbish, I just need to keep it going for another year or so). This seems to me to be the best idea, but as nobody will take it on I am having second thoughts.
    With options 1 and 2 I'd have to find a way to disconnect the buttons for opening the sunroof, just in case. I imgine that is a simple job.
    I wouldn't be capable of doing a DIY roof replacement, and I've not been able to find the part. My expectation is that this is an expensive fix, but I don't know much about cars (which is why I have a 2007 BMW x3 in the first place) so I could be wrong.
    Buying a roof box is not exactly ideal. We only do 8k miles a year but most of them are on the motorway and that extra drag is something I want to avoid.
    Any thoughts or suggestions welcome!
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    22,884
    Thanks Received:
    4,454
    Northumberland
    Country:
    • Thanks Thanks x 1
    • Like Like x 1
  4. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    19,557
    Thanks Received:
    2,186
    Devon
    Country:
    Hey John that was my first thought, some kind of tape, gotta be the way to go first. What about welding a sheet of metal over the whole lot?
    • Thanks Thanks x 1
    • Like Like x 1
  5. Bluebirdnick
    Bluebirdnick
    13 Aug 2012
    48
    Thanks Received:
    Essex
    Country:
    Just to be clear: presumably you are suggesting that I tape over the edge where the seals meet the bodywork on the outside? Any concerns that, because water was getting in, so air will get out and possibly cause it to bubble up and fail?
    I'm off to toolstation now to get some of this tape so will give it a go, but wanted to check what you were envisaging. Really appreciate the suggestions.
  6. Bluebirdnick
    Bluebirdnick
    13 Aug 2012
    48
    Thanks Received:
    Essex
    Country:
    I'm back. They don't sell it in store. Can't seem to find it anywhere having searched B&Q, wickes, screwfix, homebase so - unless anyone knows wehre it is stocked - I'll have to order for delivery and do it next weekend.
  7. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    19,557
    Thanks Received:
    2,186
    Devon
    Country:
    Wilko sell it apparently, not sure if in store though. Or maybe that god awful place The Range.
    • Thanks Thanks x 1
  8. just pumps
    just pumps
    24 May 2016
    2,760
    Thanks Received:
    469
    Country:
    If it is only the one drain pipe that has failed would water flow away to one of the others if you blocked it from inside?
    • Thanks Thanks x 1
  9. Bluebirdnick
    Bluebirdnick
    13 Aug 2012
    48
    Thanks Received:
    Essex
    Country:
    Good question. My concern is that it might overload it, and cause issues elsewhere. Although as you say - if they are working, tehre is no problem.
    If so, then what - a bit of silicone or something just to block up that one pipe at the sunroof end?
  10. Sponsored Links
  11. just pumps
    just pumps
    24 May 2016
    2,760
    Thanks Received:
    469
    Country:
    That`s what I was thinking, best to let it dry first though.
  12. Stivino
    Stivino
    11 Oct 2006
    3,258
    Thanks Received:
    327
    Midlothian
    Country:
    Often they get blocked up with little bits of vegetation and dirt. You can check if they are clear by opening the roof and carefully pouring water into the channel then, checking below the car to see if it if flowing.
    • Thanks Thanks x 1
  13. Bluebirdnick
    Bluebirdnick
    13 Aug 2012
    48
    Thanks Received:
    Essex
    Country:
    Thanks. The garage did that and said it was clear this time. It's a pity - it was a super-simple fix when we just had to unblock it!
  14. Nige F
    Nige F
    28 Jun 2005
    21,154
    Thanks Received:
    1,729
    Country:
    Then they cleared it - or was that a different garage ? I covered a van roof with 600mm wide flashband -lapped @ the joins:ROFLMAO:
    • Like Like x 2
  15. Burnerman
    Burnerman
    7 Feb 2008
    22,884
    Thanks Received:
    4,454
    Northumberland
    Country:
    Unfortunately the curvature of the roof means that all drains need to work.....collecting water just runs over the raised lip :(
    John :)
    Allow me to edit.....our local homebase seems to have plenty in stock?
    J.
  16. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,553
    Thanks Received:
    1,921
    Hertfordshire
    Country:
    Do you mean 'caravan' by any chance??
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    Andy
  17. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    6,432
    Thanks Received:
    948
    Country:
    There maybe a joint to aid the original cars assembly, usually in the boot wings. Might that joint have parted, rather than the pipe having perished?
Loading...
Share This Page
