Fixing Cables To Outside Brick/Mortar
12 Mar 2007
Cheshire
I have a couple of aeriel cables to put up, which will need to run around the outside of the house. The thing I hate when I've done this before, is using those nail-in cable clips which you usually nail into the mortar between bricks. A lot of the time, the mortar disintegrates and makes a right mess, they don't go in securely, and if any need removing later half of the mortar of the whole house seems to come out or work loose! Are there any alternatives to these, or any other methods used perhaps. I've been looking for those screw in type but haven't found any yet, also thought about small blobs of silicone along the cable to secure it to the wall. Thanks.
You can get things like small rawlplugs designed so that you drill a small hole, insert the plug and then nail in the normal clip. Neat and cheap with no worries about falling off with frost, sun etc. Screwfix, TLC do them, same maker as the clips. HTH
When you take the cable into the house take the cable down below the hole in the wall and then U turn it to come up to the hole. This is a "rain drip" which reduces the amount of water that will enter the hole. Do not make it a tight bend as this can damage the cable.
Also drill the hole on a slight slope with the inside end higher than the outside end.
Any chance of posting the link to the screwfix version of these? I had a quick scan of the SF website but couldn't spot them. I'm placing a SF order in a day or two and a box of these clips could come in handy...
Yes, if a link could be posted that'd be great, I can't find them also.
Isn't there a cable clip version which screws into the wall, i.e. it has a screw instead of a nail.
Or you could use these jobbies.
You drill a hole in the masonry, and hammer it into the hole so just the little square bit at the top is left on show. You can then tie wrap as many (or few) cables as you like to it.
