Flex monobloc tap connectors with female ends - help please
dub
11 Sep 2009
Gloucestershire
The flexible connector to the cold feed of my Blanco monobloc tap has just started slow drip so I want to replace it.
It screws into the tap directly one end (I'm guessing 12mm bore based on the same nut size) and the other end is a female tap type connector with a washer inside that connects to an elbow.
I cannot find anywhere a replacement with a female end - only 15mm compression end with an olive which is no good.
Does anyone know where I could get a replacement as I cannot find them anywhere - even online after several hours searching.
Phil
Can you post a pic please.
I would say it will be easy once we know what you are after.
use the comp one remove the nut and olive and use one of these
1/2"" bsp female socket :idea:
  • Thanks
Reactions: dub
