Hi all
I've got a situation where I need power behind a built in oven, both for the oven and the ignition for the gas hob. I'm thinking of converting the existing single switched outlet to a flex outlet (as there will be no room for two plugs). However as I need two outlets should I provide two flex outlets or can I 'tee' into one? Or is there a better way to do this job.
Thanks in anticipation
Brian
Brian
