Hi all
One of the walls on the side of a staircase is plasterboard stud wall, which runs all the way from the ground floor to the upstairs ceiling. I noticed a significant crack in the caulk between the side of the staircase and this wall, and found the reason is that the plasterboard wall is quite flexible. If I push on it, it moves by about 5mm away from, the side of the staircase. It is definitely the whole wall moving and not just the plasterboard being loosely attached to the studs.
How could this problem be fixed so the wall doesn't move so much and cause the caulk to crack? One idea I had is to screw through the side board on the staircase into the studs, but any other ideas would be appreciated. I'll attach photos (in the photos I have removed the caulking)
Thanks for any replies
