Floating sockets..
Thats how you do it, I've put one of those 50mm desk tidy things in since.
Its designed to be a portable extension lead not part of a fixed installation.....although it will work fine and is safe its not what its for so if came across it I would remove it and fix a proper back box and socket.
I'll go back to this. <134.1.1>
I think we're definitely going to have to 'agree to disagree' on this :-)
Just to make sure I'm not doing you an injustice ... are you saying that a trailing socket lying on the floor, wired with flex that went through a hole in a shelf to a plug that was plugged into a wall mounted socket would be 'acceptable', whereas it would not be acceptable if, rather than having a plug on it's end, the flex was 'hard-wired' into a wall-mounted FCU, switch, outlet plate, connector block/Wagos (behind blank plate) etc. etc. ... and that, given that you have cited 134.1.1, you would actually give a C3 to the latter?
Yes C3...
Whats 132.12 again?
No wrong one cant remember im out at the moment...
But still C3 yeah agree to disagree :giggle:
Yes C3... Whats 132.12 again? ... No wrong one cant remember im out at the moment...
132.12 is about 'accessibility of electrical equipment' - presumably no problem with either what you or I were describing. 134.1.1, which you previously mentioned, is about 'good workmanship', and hence is a 'catch-all' that can mean anything to anyone :-)
I'm rather surprised. It might sound like a silly, maybe even facetious, hypothetical question to ask, but your answer might possibly help me to understand your thinking, so ....
... if you still regard the 'latter situation' described in my last post as not being acceptable, would that remain the case if I super-glued the plug to the socket?
And we are back to 134.1.1
Im never going to say an un-fixed socket is acceptable...it needs improving
...final answer.
May I just comment on siting reg 1341.1.1?
In many ways perhaps the most powerfull reg in the book or one of them and often overlooked in some respects.
However this often get thought of by the statement "Not as the manufacturer intended!"
In other words if we use something as it was intended then always OK but if we use it not as intended is never OK!
I strongly disagree with that interpretation.
Yes we are encouraged to trust those who made it, indeed until recently their design was "paramount" whereas nowadays that has been downgraded very slightly to "must be taken into account".
I do not disgree with putting a very large of amount of trust in the manufacturers as a gen rule of thumb no problem usually , it is their product, they made it, tested it, probably have extensive knowledge of what it can/can not do and can often be relied upon.
But always remember, new inventions, new ideas, are not forbidden and might sometimes actually be encouraged providing that due diligence and sound engineering judgement is always used.
New inventions, new ideas can include sometimes using an existing product in ways the makers might not have envisaged them.
Caution is always advised if you deviate from the original intention because you might not have some vital knowledge but it is never totally forbidden.
It is never always wrong in every case, it might or might not be a good idea.
That is how we progress (sometimes!).
To wander outside the design of the makers then you become the designer (of that idea) and you accept the responsibillity of so doing.
Its obviously been discussed before....similar to our discussion actually....difference this socket has no gland but, im sticking to it. :mrgreen:
I haven't checked the link as I dislike the arrogant way the site is run and no longer have an account there ...
However I had forgotten but believe I read (and possibly posted in) that thread or one like it a while back, is that the one which finished immediately after someone quoted the reg something along the lines of
infrequently moved equipment may be connected using solid cable
I don't require multiple posts correcting my paraphrasing of the post or the reg but posting the reg here, or its recent version, may assist in decision making.
Im never going to say an un-fixed socket is acceptable...it needs improving ...final answer.
Oh - in that case it looks as if I have doing some misunderstanding - since, given that you wrote ...
Would 3 core flex and an extension lead type socket be acceptable to you?
Plugged into a fixed socket? Yes.
... I presumed that you were subsequently saying that this (per pic) would be OK so long as there was a proper 'training socket ("an extension lead type socket" on the other end of the flex ...
It now sounds as if that probably wasn't what you meant, so I would be grateful if you could clarify. Thanks.
May I just comment on siting reg 1341.1.1? .... In many ways perhaps the most powerfull reg in the book or one of them and often overlooked in some respects.
I don't know about "most powerful" but it could be said that it is 'all-encompassing'. If one feels that 'good workmanship' includes compliance with all explicit regs in BS7671, then 134.1.1 requires one to comply with every other reg "and more", with that "more" being so vague and subjective that it could include almost anything to any particular person!
However this often get thought of by the statement "Not as the manufacturer intended!" .... In other words if we use something as it was intended then always OK but if we use it not as intended is never OK! .... I strongly disagree with that interpretation. ... Yes we are encouraged to trust those who made it, indeed until recently their design was "paramount" whereas nowadays that has been downgraded very slightly to "must be taken into account".
Quite, as you say, the authors of BS7671 seem to agree with you since they have appreciably 'weakened' the reg (I would personally say more than "downgraded very slightly") in recent times. It's not that long ago that there was an explicit requirement to comply with MIs - strictly speaking even if (as sometimes did happen) those MIs were clearly incorrect - but today's requirement to 'take the MIs into account' allows for much discretion and judgement.
What worries me a little is that, as we have seen to some extent in this thread, some people might (by application of their personal judgement/discretion) give C3s (or maybe even C2s) to things that were not non-compliant with any explicit regs, and which some (maybe many) others would find acceptable, on the basis of their own personal opinion about 'good workmanship' (citing 134.1.1).
There's a fridge on the other end of that flex.
Fair enough, but when you wrote this 'yes' (below) to Sunray, were you not saying that a (purpose-made) 'trailing socket' (which is what I assumed he meant by "an extension lead type socket") on the end of the flex would also be OK? ...
