About to start the 2nd part of the extension which is the main rear build. The architect has drawn a typical slab laid on insulation. to the extension. I want the existing rear rooms that will form part of the larger new room to have the same floor construction.
I don't like the idea of slabs so started looking at Block and Beam flooring which would be ideal to run in the existing and new locations. The problem is that there is not enough depth from existing finished floor level less screed, insulation, block and beam and then to leave a 150mm void for air flow.
The question then came of why cant traditional suspended flooring be used? Obviously this would need to be insulated between the joists to current BR's. My BCO has allowed me to do this in teh smalle front extension.
Is there an issue with teh traditional method and why don't people use now days. Surely it is perfect for running services and any future alteration works?
