Hello
Hopfully this is in the right forum.
I have a house which had an extension before I moved in. The garage has been widened and another floor buildt above it making an extra bedroom.
The garage is 12ft (3.65m) wide.
The floor ceiling/floor joists are 6.5" (16.5cm) x 1 7/8" (5cm) and spaced at 16" (40cm) centres and mounted in metal hangers.
When a perons walks around the bedroom the floor can be felt by another person to move as they walk. Also there is an en-suit with the stud wall which forms it built above one of the floor joists. The door the the en-suit rattles when someone walks across the floor indicating to me that the floor is moving.
I do realise that some movement is always there but I'm concerned there is too much.
Are the floor joists used correctly sized for the span?
what could I do to reenforce the floor?
Any ideas or suggestions greatly accepted.
Steve
Steve
