flooring expansion gap around door jamb
7 Jul 2009
Yorkshire
hi. i've paid for somebody to lay my oak flooring . The skirting was left on so i will be using 16 x 16 quadrant beading... My problem is that instead of cutting out the door jamb and placing the flooring under this, he has cut the flooring around the door jamb. this looks a little un sightly. any tips to make this look a little better would be appreciated .
it varies on the long straights its roughly 10 mm but around door jamb it varies from 5 - 12 mm
i would ask him to undercut the door frame and architraves rather than extend the gap to 12mm around it although he will have a gods own job to release the undercut section with the floor in situ :roll:
no will get one up tommorow. allthough i dont think this will be an option feel bit cheeky as hedid this cheap. unless i pay him again :? seems like i may jus have to fill with sealant or wood filler any suggestions on these? thanks
no you need expansion nothing hard oo err misses :oops:
maybe white silicon iff your paint is white not ideal but flexible
i am sure woodulike will have an excelent product to fill the gap lol :D
haha , yes ive got some white silicon and the beading and skirts are white so will have to do this. or try some woodulike :wink: and next time ask to undercut frames. thanks big all
Should be able to cut with a bosch p180e or similar, protect floor with thin card and tape and you can get cork strips to pack gaps which allow expansion.
